[gdal-dev] Warping EUMetsat MSG-4 MPE dataset to webmercator projection
Andre Joost andre+joost at nurfuerspam.de
Wed Apr 25 05:29:37 PDT 2018
Am 24.04.18 um 15:40 schrieb Menno van Scheers - HUSS:
> Just verified this.
> Warping the original dataset with the following commandline :
> gdalwarp -t_srs "+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs "
> -te -65 -65 65 65 -te_srs "+proj=longlat +ellps=WGS84 +datum=WGS84
> +no_defs" "C:\Temp\nl\newtiff.tiff" "C:\temp\nl\oldgdalwarp.tiff"
> Succeeds in v2.1.0 with a lot of tolerance condition errors. Fails in
> v2.2.4 with  : ERROR 1: Too many points (5625 out of 5625) failed to
> transform, unable to compute output bounds.
Just checked here: It worked up to GDAL 2.2.3 (from Gisinternals) on the
full target extent, and fails with the current 2.2.4.
And the result was not all black.
HTH,
Andre Joost
