[gdal-dev] Warping EUMetsat MSG-4 MPE dataset to webmercator projection
Andre Joost andre+joost at nurfuerspam.de
Wed Apr 25 05:45:03 PDT 2018
Am 25.04.18 um 14:29 schrieb Andre Joost:
> Just checked here: It worked up to GDAL 2.2.3 (from Gisinternals) on the
> full target extent, and fails with the current 2.2.4.
... and gdal 2.4.0dev from Gisinternals works the same as 2.2.3.
So only the OSGEO4W version 2.2.4 fails. Maybe because of PROJ 5.0.1?
My Linux with Ubuntugis is at v 2.2.2 and works as expected too.
HTH,
Andre Joost
