[gdal-dev] VRT of VRTs with overviews. They do not seem to be used.
Even Rouault
even.rouault at spatialys.com
Fri Aug 3 09:17:45 PDT 2018
Christoph,
gdaladdo always start from the full resolution layer (or the preceding
overview in case of cascading overview), hence what you observe. And even if
it did start from the nearest existing overview level, in your full scenario
of a VRT of VRT, with each 'bottom-level' VRT having overviews, that wouldn't
ause the overall VRT to be able to expose overview bands.
That said, there's a trick you can use
If you do:
gdal_translate second_level.vrt tmp.tif -outsize 3.125% 3.125% -of GTiff
mv tmp.tif second_level.vrt.ovr
you'll get a 1/32 overview, and this will be able to use the overviews of the
bottom-level VRTs
and you can then run gdaladdo on second_level.vrt.ovr
Regarding the fact the gdalinfo first_level.vrt only reports overviews of size
500x500, 250x250, this is because of an optimization of the VRT driver that do
not report overviews smaller than 128x128.
Even
http://www.spatialys.com
