[gdal-dev] Recommended OGR Driver For Very Large Vector Data
Patrick Young patrick.mckendree.young at gmail.com
Fri Aug 3 11:45:41 PDT 2018
Hi all,
I've been trying to figure out a good format to store some very large
vector data in.  Basically, its a bunch of really dense polygons describing
the cutlines that compose a mosaic.  We've had reasonable success using
zipped shapefiles, but on the larger guys we're exceeding the 2GB file
size, so a more modern alternative is desired.
FileGBD worked alright but having to build GDAL with the ESRI driver to
write them is not desirable.  We also tried a GeoPackage, but it seemed a
little slow to read in QGIS.
The dream would be a nicely compressed format that can be spatially indexed
so that we can serve them up efficiently with mapserver.  Any
recommendations are greatly appreciated!
Thanks,
Patrick
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180803/a698db33/attachment.html>
