[gdal-dev] Recommended OGR Driver For Very Large Vector Data
Jeff McKenna jmckenna at gatewaygeomatics.com
Fri Aug 3 11:52:19 PDT 2018
Hi Patrick,
In terms of speed and MapServer, considering you have large vector data
and require good indexing, I always use and recommend PostGIS.
(of course if you asked this on the MapServer-users list you would get a
whole lot of different opinions)
But that is my initial recommendation, for your stated needs.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
https://gatewaygeomatics.com/
On 2018-08-03 3:45 PM, Patrick Young wrote:
> Hi all,
> I've been trying to figure out a good format to store some very large
> vector data in.  Basically, its a bunch of really dense polygons
> describing the cutlines that compose a mosaic.  We've had reasonable
> success using zipped shapefiles, but on the larger guys we're exceeding
> the 2GB file size, so a more modern alternative is desired.
> FileGBD worked alright but having to build GDAL with the ESRI driver to
> write them is not desirable.  We also tried a GeoPackage, but it seemed
> a little slow to read in QGIS.
> The dream would be a nicely compressed format that can be spatially
> indexed so that we can serve them up efficiently with mapserver.  Any
> recommendations are greatly appreciated!
> Thanks,
> Patrick
