[gdal-dev] Recommended OGR Driver For Very Large Vector Data
Jeff McKenna jmckenna at gatewaygeomatics.com
Fri Aug 3 12:16:42 PDT 2018
My next choice for customers (in cases of a hard file requirement) is
always Spatialite (sqlite3 + libspatialite wrapped into a single file).
I still prefer and use that to deliver, over the heavier GPK format.
(again, everyone has their own preferences, I'm just sharing my 18+
years of MapServer experience with you here ha).
Have a nice weekend,
-jeff
On 2018-08-03 4:08 PM, Patrick Young wrote:
> Ah right of course!  I should have said that we deliver these things to
> customers, so a file format is needed.  We've have had good luck serving
> simplified versions of these things out of zipped shapefiles from S3 via
> mapserver so the thought was maybe the same trick would work with the
> right format without having to import them into the DB.
> P
> On Fri, Aug 3, 2018 at 12:52 PM, Jeff McKenna
> <jmckenna at gatewaygeomatics.com <mailto:jmckenna at gatewaygeomatics.com>>
> wrote:
>     Hi Patrick,
>     In terms of speed and MapServer, considering you have large vector
>     data and require good indexing, I always use and recommend PostGIS.
>     (of course if you asked this on the MapServer-users list you would
>     get a whole lot of different opinions)
>     But that is my initial recommendation, for your stated needs.
>     -jeff
>     Jeff McKenna
>     MapServer Consulting and Training Services
>     https://gatewaygeomatics.com/
>     On 2018-08-03 3:45 PM, Patrick Young wrote:
>         Hi all,
>         I've been trying to figure out a good format to store some very
>         large vector data in.  Basically, its a bunch of really dense
>         polygons describing the cutlines that compose a mosaic.  We've
>         had reasonable success using zipped shapefiles, but on the
>         larger guys we're exceeding the 2GB file size, so a more modern
>         alternative is desired.
>         FileGBD worked alright but having to build GDAL with the ESRI
>         driver to write them is not desirable.  We also tried a
>         GeoPackage, but it seemed a little slow to read in QGIS.
>         The dream would be a nicely compressed format that can be
>         spatially indexed so that we can serve them up efficiently with
>         mapserver.  Any recommendations are greatly appreciated!
>         Thanks,
>         Patrick
