[gdal-dev] HDF5 and NetCDF now have VSI support
Even Rouault even.rouault at spatialys.com
Wed Aug 8 05:30:56 PDT 2018
> A concrete example: you should probably not setup a
> /vsimem asset from one thread while another thread is reading a uffd backed
> asset
Just a small correction: James meant here not to mix uffd with the use of the
API in cpl_virtualmem.h ( CPLVirtualMemNew() and the like ).
/vsimem/ itself has nothing to do with cpl_virtualmem.h and so can be used
with uffd without problem.
Even
http://www.spatialys.com
