[gdal-dev] HDF5 and NetCDF now have VSI support
James McClain james.mcclain at gmail.com
Wed Aug 8 06:08:22 PDT 2018
Ah yes, my apologies.
On Wed, Aug 8, 2018 at 8:30 AM Even Rouault <even.rouault at spatialys.com>
wrote:
> > A concrete example: you should probably not setup a
> > /vsimem asset from one thread while another thread is reading a uffd
> backed
> > asset
> Just a small correction: James meant here not to mix uffd with the use of
> the
> API in cpl_virtualmem.h ( CPLVirtualMemNew() and the like ).
> /vsimem/ itself has nothing to do with cpl_virtualmem.h and so can be used
> with uffd without problem.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
"I prayed for freedom for twenty years, but received no answer until I
prayed with my legs."
     -- Frederick Douglass
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180808/3e30d199/attachment.html>
