[gdal-dev] HDF5 and NetCDF now have VSI support
Even Rouault even.rouault at spatialys.com
Sun Aug 26 12:07:42 PDT 2018
I've pushed a change in master that now enables /vsi support for HDF5 for all
operating systems, and not just Linux >= 4.3. This uses the HDF5 Virtual File
Driver mechanism:
https://support.hdfgroup.org/HDF5/doc/TechNotes/VFL.html
which allows to plug a custom low-level I/O layer
(In theory, as netCDF V4 uses HDF5 underneath, this could be available for it
too, but the use of HDF5 is hidden by the netCDF API, so this would require
patching libnetcdf)
Even
http://www.spatialys.com
