[gdal-dev] pthread_setspecific() failed error
Even Rouault
even.rouault at spatialys.com
Thu Aug 16 00:26:14 PDT 2018
On mercredi 15 août 2018 16:57:15 CEST you wrote:
> The grass 7.4.0 dependency is causing the error. Compiling without grass
> support produces binaries that do not have this issue. I'm not sure yet if
> this is an issue with the grass build, the way I compiled gdal to support
> it, or something else. I will provide an update if I find out.
Ah interesting, a reason might be that your GRASS binaries are not compiled
with the GDAL version you build, hence chaos at runtime.
The normal procedure would be:
1) build GDAL without GRASS support
2) build GRASS against the above compiled GDAL
3) build GDAL again with GRASS support or build the GDAL-GRASS plugin
Even
> The operating system is CentOS 7
> -Colleen
> On Mon, Aug 13, 2018 at 11:01 PM, Even Rouault <even.rouault at spatialys.com>
> wrote:
> > On lundi 13 août 2018 16:44:24 CEST Colleen Rooney wrote:
> > > Hello,
> > > I am attempting to build gdal version 2.3.1 from source. I am using gcc
> > > 7.2.0, and enabling support for proj4 version 5.1.0, grass version
> > > 7.4.0,
> > > xerces-C version 3.1, hdf5 version 1.10.2, netcdf version 4.4.1.1,
> > > python
> > > version 3.6.4, and perl version 5.16.3. Configure, make, and make
> > > install
> > > all complete. However when the resulting executables are run I get an
> > error
> > > such as the following:
> > > $ ./gdalinfo --version
> > > GDAL 2.3.1, released 2018/06/22
> > > CPLGetTLSList(): pthread_setspecific() failed!
> > > I have hit a wall trying to figure out what is causing this error. Any
> > help
> > > would be appreciated, let me know any additional information you
> > > require!
> > This is a weird one. Which operating system is this ?
> > Can you retry building GDAL without any of the dependency at all and see
> > if
> > that makes a difference ?
> > Even
> > Spatialys - Geospatial professional services
> > http://www.spatialys.com
