[gdal-dev] Offsets in url of geotiff
Guy Doulberg
guyd at satellogic.com
Wed Aug 22 23:29:27 PDT 2018
Hi
I want to share with you an idea I had,
I am storing rasters as cloud optimized GeoTiff, these rasters can cover
very big areas.
I was thinking it could be super, if I could share a link to my colleagues
of a raster with the offset they need encoded in the raster.
for example:
url = "/vsicur/http://location/#srcwin=(xoff,yoff,szie,ysize)"
if you will execute
gdalinfo url
you will get the same info to the output raster of
gdal_translate -srcwin xoff yoff xsize ysize
using that url you will be able to execute any gdal command that run on a
raster, and using the cog gdal will read only the relevant data.
That could be very useful for me, cause then I could decouple easily the
raster I store on my cloudstorage and the raster I share.
WDYT?
Guy
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180823/9a9606e5/attachment.html>
