[gdal-dev] VRT schema integer types serialization
GUIMMARA, Sébastien (External) [FR] sebastien.guimmara.external at airbus.com
Fri Aug 24 01:54:08 PDT 2018
Thanks for the reply.
Did you mean it is fine to do so on my side, or would it be fine to have in the official GDAL source ?
-----Message d'origine-----
De : Even Rouault [mailto:even.rouault at spatialys.com]
Envoyé : vendredi 24 août 2018 10:36
À : gdal-dev at lists.osgeo.org
Cc : GUIMMARA, Sébastien (External) [FR]
Objet : Re: [gdal-dev] VRT schema integer types serialization
On vendredi 24 août 2018 07:52:04 CEST GUIMMARA, Sébastien (External) [FR]
wrote:
> xs:unsignedInt
Replacing uses of xs:nonNegativeInteger with the custom nonNegativeInteger32
would be fine, and modifying that one to be base on xs:unsignedInt sounds good
too
http://www.spatialys.com
Please consider the environment before printing this email message.
Ce courriel (incluant ses éventuelles pièces jointes) peut contenir des informations confidentielles et/ou protégées ou dont la diffusion est restreinte. Si vous avez reçu ce courriel par erreur, vous ne devez ni le copier, ni l'utiliser, ni en divulguer le contenu à quiconque. Merci d'en avertir immédiatement l'expéditeur et d'effacer ce courriel de votre système. Airbus DS Geo décline toute responsabilité en cas de corruptionpar virus, d'altération ou de falsification de ce courriel lors de sa transmission par voie électronique.
This email (including any attachments) may contain confidential and/or privileged information or information otherwise protected from disclosure. If you are not the intended recipient, please notify the sender immediately, do not copy this message or any attachments and do not use it for any purpose or disclose its content to any person, but delete this message and any attachments from your system. Airbus DS Geo disclaims any and all liability if this email transmission was virus corrupted, altered or falsified.
Airbus DS Geo SA (325 089 589 RCS Toulouse) - Siege social: 5, rue des Satellites, 31400 Toulouse, France.
