[gdal-dev] Support for S-100 and S-102
Even Rouault even.rouault at spatialys.com
Thu Aug 30 07:54:53 PDT 2018
On jeudi 30 août 2018 07:29:12 CEST Mike wrote:
> The multiple field/subfields - I think gdal already does this for S-57 on
> DSID. It just prefixes the subfields with the field name.
> However -side note:  it seems the DSID_ISDT (issue date) is incorrect, it
> just has the same value as DSID_UADT (update application date).
From a quick look at the driver code, I can't see an obvious copy&paste-like
error. If you believe there's a bug in the driver, and that's just not how the
dataset metadata is filled, please file an issue at
https://github.com/OSGeo/gdal/issues with an attached or linked dataset.
Even
http://www.spatialys.com
