[gdal-dev] Support for S-100 and S-102
Mike
mswope at gmail.com
Thu Aug 30 08:51:16 PDT 2018
I can't get to it right now, but the new date would be found in the update
file. So this would only occur on cells with updates. If I open an update
file (.001+) in a text editor, I see the date on the second line.
I'm just using the first cell found @
www.charts.noaa.gov/ENCs/ENCsIndv.shtml (US1AK90M). That page also tells
you the update application date and issue date.
I can try to submit an issue later today.
On Thu, Aug 30, 2018, 8:54 AM Even Rouault <even.rouault at spatialys.com>
wrote:
> On jeudi 30 août 2018 07:29:12 CEST Mike wrote:
> > The multiple field/subfields - I think gdal already does this for S-57 on
> > DSID. It just prefixes the subfields with the field name.
> > However -side note: it seems the DSID_ISDT (issue date) is incorrect, it
> > just has the same value as DSID_UADT (update application date).
> From a quick look at the driver code, I can't see an obvious
> copy&paste-like
> error. If you believe there's a bug in the driver, and that's just not how
> the
> dataset metadata is filled, please file an issue at
> https://github.com/OSGeo/gdal/issues with an attached or linked dataset.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180830/9dbde5fb/attachment.html>
