[gdal-dev] Motion: adopt RFC 72: Run tests with pytest
Kurt Schwehr
schwehr at gmail.com
Mon Dec 10 14:07:31 PST 2018
To follow on to Howard's comment about testing in python...
I'm looking forward to the day that GDAL can drop all python 2.x support
and testing!
And anyone working on C++ testing is welcome to the code here. I'll
happily donate it with a license change to GDAL (it's apache 2.0 right
now). You are free refactor however. Or just use any bits that you think
are helpful if going to a different testing library. I can also donate
some of the 80+k files in my fuzzer corpus as test inputs that cover weird
corners of the code.
https://github.com/schwehr/gdal-autotest2/tree/master/cpp
On Mon, Dec 10, 2018 at 11:39 AM Howard Butler <howard at hobu.co> wrote:
> +1
> I watched the ticket traffic and shuddered :) Thank you. GDAL's testing
> probably predates five or six Python testing regimes/eras. I also have
> the concern about GDAL's testing going through Python, but this RFC will
> make it much easier for people to contribute and improve the story.
> Congratulations on a huge lift!
> Howard
> On 12/9/18 9:48 PM, Kurt Schwehr wrote:
> > I haven't had a chance to read the RFC yet, so I can't yet vote.
> However,
> > a huge thank you to Craig and everyone else who put in effort to make
> this
> > happen!
> > On Sun, Dec 9, 2018 at 7:05 PM Craig de Stigter <
> > craig.destigter at koordinates.com> wrote:
> >> Jonathan
> >>> it's worth spending a little thought on coming up with a scheme for
> >> test-ids.
> >> I've been through the list of parametrized tests and tweaked the `ids`
> >> kwargs to make them a little more helpful at first glance:
> https://github.com/OSGeo/gdal/pull/963/commits/8db599e7bc08b7dc73d81591898ed0f5f4243a58
> >> I didn't see any way to use `pytest_make_parametrize_id` really; IDs
> >> rightly vary enough between tests that I can't see that hook being very
> >> useful here.
> >> Cheers
> >> Craig de Stigter
> >> On Mon, 10 Dec 2018 at 09:59 jratike80 <
> >> jukka.rahkonen at maanmittauslaitos.fi> wrote:
> >>> +0
> >>> -Jukka Rahkonen-
> >>> Even Rouault-2 wrote
> >>>> PSC members,
> >>>> gentle reminder to cast your vote on this.
> >>>> Thanks,
> >>>> Even
> >>> Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
> >>> _______________________________________________
> >>> gdal-dev mailing list
> >>> gdal-dev at lists.osgeo.org
> >>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20181210/aeee0ee3/attachment.html>
