[gdal-dev] Motion: adopt RFC 72: Run tests with pytest
Jonathan Moules
jonathan-lists at lightpear.com
Mon Dec 10 15:30:18 PST 2018
Hi Craig,
For my suite I've used pytest_make_parameterize_id to auto-create id's
using the first parameterised value as the id name if that parameter is
called "_" (just underscore - the Python convention for a throwaway
variable). It works really well, although would need some work for
backwards compatibility.
So for example your code of:
@pytest.mark.parametrize('epsg_code,epsg_broken', [
[2758, False], # tmerc
[2036, True], # sterea # failure caused by revert done in r22803
[2046, False], # tmerc
Which has the test "purpose" as a comment (how I used to do it), becomes:
@pytest.mark.parametrize('_, epsg_code,epsg_broken', [
["tmerc", 2758, False],
["sterea", 2036, True], # failure caused by revert done in r22803
["tmerc - 2nd," 2046, False],
And so on. Then if the test fails you see the (hopefully meaningful)
"sterea----". The advantage is that the id is there with the test rather
than trailing it in a separate list that's just asking to suffer from
bitrot.
If you're interested, the code is simple and basically this:
def pytest_make_parametrize_id(argname, val):
""" Create a nice readable test id based on "_".
Doesn't quote as expected and stop at the id alone. Instead it
keeps going through the rest of the args.
Also keeps track of test numbers so PyCharm/PyTest doesn't change
their order to semi-alphabetical
:param argname: parameterised arg name
:param val: parameterised value name
:return: string suitable for a test name
# We keep a test_num globally so it works across tests; not yet
investigated a better way of know when we're on the next test
global test_num
if argname == '_':
test_num += 1
# Replace spaces with underscores so that we can run the given
test individually.
# Can't do that with spaces in test names.
name = "{id}={name}".format(id=test_num, name=val.replace(' ',
'_'))
return name
else:
# We don't want any value for any other field.
# Can't leave it as an empty string because then PyTest ignores it.
return "-"
Just a thought.
Jonathan
On 2018-12-10 03:04, Craig de Stigter wrote:
> Jonathan
> > it's worth spending a little thought on coming up with a scheme for
> test-ids.
> I've been through the list of parametrized tests and tweaked the `ids`
> kwargs to make them a little more helpful at first glance:
> https://github.com/OSGeo/gdal/pull/963/commits/8db599e7bc08b7dc73d81591898ed0f5f4243a58
> I didn't see any way to use `pytest_make_parametrize_id` really; IDs
> rightly vary enough between tests that I can't see that hook being
> very useful here.
> Cheers
> Craig de Stigter
> On Mon, 10 Dec 2018 at 09:59 jratike80
> <jukka.rahkonen at maanmittauslaitos.fi
> <mailto:jukka.rahkonen at maanmittauslaitos.fi>> wrote:
> +0
> -Jukka Rahkonen-
> Even Rouault-2 wrote
> > PSC members,
> > gentle reminder to cast your vote on this.
> > Thanks,
> > Even
> Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20181210/e47db284/attachment.html>
