[gdal-dev] running autotest locally
Even Rouault even.rouault at spatialys.com
Tue Dec 11 10:49:10 PST 2018
On mardi 11 décembre 2018 18:44:25 CET Alan Stewart wrote:
> I'm trying to run GDAL autotest locally on my Windows box. I've tried to
> follow appveyor.yml very closely, but possibly there is some additional
> configuration required that is not included in this script?
Beware of the merge today in master of RFC 72 that overhauls the testing suite
with the use of pytest:
https://trac.osgeo.org/gdal/wiki/rfc72_pytest
> In particular,
> the gdrivers/postgisraster.py tests are skipped because
> postgisraster_init() finds SRID-26711 to be missing from spatial_ref_sys.
The postgisraster.py tests require running the
autotest/gdrivers/data/load_postgisraster_test_data.sh script, so only work
easily from Unix.
Even
http://www.spatialys.com
