[gdal-dev] Ubuntu & Travis
Alan Stewart
astewart at terragotech.com
Fri Dec 14 09:50:26 PST 2018
Ubuntu 18.04.1
Given all the required software dependencies are installed, shouldn't I be able to perform the same steps shown in the Travis log to perform the same tests? Apparently not, there seems to be other Travis configuration happening outside of the files in the git repository.
I get the following error when running ci/travis/ubuntu_1804/install.sh:
Checking for libFileGDBAPI.so in in /home/astewart/Documents/GitHub/OSGeo/gdal/FileGDB_API-64gcc51/lib... configure: error: not found.
$PWD/FileGDB_API-64gcc51 is embedded in install.sh, so it appears this cannot be overridden without editing the script. Manipulating the working directory when starting the script seems risky... Any better suggestions?
Alan Stewart
Senior Software Engineer
TerraGo Technologies
3200 Windy Hill Road, Suite 1550W
Atlanta, GA 30339 USA
O. +1 678.391.9615
www.terragotech.com<applewebdata://B24C0762-C7C9-4431-8518-ACC915448B89/www.terragotech.com>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20181214/882d0825/attachment-0001.html>
