[gdal-dev] optimal vsicurl settings for merging range requests
Even Rouault
even.rouault at spatialys.com
Tue Dec 18 15:22:39 PST 2018
On mardi 18 décembre 2018 14:20:08 CET Scott Henderson wrote:
> There are many environment variables for optimizing access to remote
> geotiffs via GDAL’s /vsicurl/ interface. I’ve noticed that directly
> downloading a file via curl can be much faster (~4x) than pulling the
> entire file via gdal_translate or gdalmanage, and I think this is due to 1
> GET request versus 10s of GET requests. Here is an example using Landsat8
> on Google Cloud:
> In brief it seems there is a limit for
> GDAL_HTTP_MERGE_CONSECUTIVE_RANGES=YES that I’m missing. If the entire file
> is requested, I was expecting 2 GET requests (1 to read the metadata and
> another to retrieve the data).
Scott,
Actually you would need to define 2 extra env variables for that:
GDAL_MAX_RAW_BLOCK_CACHE_SIZE=120000000
(120 MB, the size of your uncompressed raster)
to overcome a 10 MB limit in the GeoTIFF driver for range request merging.
(undocumented)
and
GDAL_SWATH_SIZE=120000000
to increase the default swath size used by the general raster copy mechanism
of GDALDatasetCopyWholeRaster()
( https://trac.osgeo.org/gdal/wiki/ConfigOptions#GDAL_SWATH_SIZE )
With that you'll get 3 GET requests. The last one is a smallish one, probably
because GDALDatasetCopyWholeRaster() isn't smart enough to issue a request for
the whole raster due to the bottom block being partial.
But if you need to convert a whole raster, you could just use the HTTP driver,
that is use a https:// URL directly as the dataset nmae (you may need to set
GDAL_SKIP=DODS to avoid the DODS driver to kick in inappropriately), which
will save you from setting all those magic incantations, and will consume less
memory, since the above mechanisms will add caches at various layers (in the
GTiff driver, in GDALDatasetCopyWholeRaster() and in the /vsicurl layer),
whereas the HTTP driver will just ingest the whole raster.
Even
http://www.spatialys.com
