[gdal-dev] Coordinates Axis Order for EPSG:2193
Even Rouault
even.rouault at spatialys.com
Thu Feb 8 10:16:04 PST 2018
Hi Jeremy,
> Is there a way to report the axis order that GDAL understands internally
> for automatically swapping coordinates axis order when dealing with OGC/GML
> services?
> EPSG is defined as North/East order and is correct in
> http://epsg-registry.org/export.htm?wkt=urn:ogc:def:crs:EPSG::2193
> However when I run gdalsrsinfo -o wkt -p "EPSG:2193" using GDAL 2.2.3 it
> does return any information relating to axis:
Yes, use "EPSGA:2193"
note the A after EPSG for Axis
If using EPSG, axis will be stripped off for lat-long geodetic SRS, and northing-easting
projected SRS.
Whereas EPSGA always retain axis order
The rationale for the EPSG:xxxx behaviour is that most of the time the raster or vector data
in those "inverted axis" CRS will actually be returned in GIS friendly order, and thus the axis
info would be misleading.
> However back in 2013 the gdalsrs did report it:
> https://lists.osgeo.org/pipermail/gdal-dev/2013-March/035624.html.
Yes, at that time stripping off was only implemented for lat-long geodetic SRS. It has since
then being extended to northing-easting projected SRS.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180208/afd02f7d/attachment.html>
