[gdal-dev] Coordinates Axis Order for EPSG:2193
Jeremy Palmer palmerjnz at gmail.com
Thu Feb 8 10:24:40 PST 2018
Hi Even,
On Fri, Feb 9, 2018 at 7:16 AM, Even Rouault <even.rouault at spatialys.com>
wrote:
> Yes, use "EPSGA:2193"
> note the A after EPSG for Axis
> If using EPSG, axis will be stripped off for lat-long geodetic SRS, and
> northing-easting projected SRS.
> Whereas EPSGA always retain axis order
> The rationale for the EPSG:xxxx behaviour is that most of the time the
> raster or vector data in those "inverted axis" CRS will actually be
> returned in GIS friendly order, and thus the axis info would be misleading.
Thank you, makes perfect sense.
Another day, another another axis order issue :-(
Cheers
Jeremy
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180209/3bac3a91/attachment.html>
