[gdal-dev] Constructing GDAL_WMS XML files for TMS servers
Julierme Pinheiro
juliermeopensourcedeveloper at gmail.com
Thu Feb 22 07:17:39 PST 2018
Hi all,
I found this discussion related to my question: http://osgeo-org.1560.x6.
nabble.com/gdal-dev-Constructing-GDAL-WMS-XML-files-for-TMS-servers-
td5033787.html.
I have several sar images in geoserver and I need to create a XML file for
each TMS service in order to load them in Qgis.
For the wmts services I used the folowing gdal function:
gdal_translate "WMTS:http://maps.wien.gv.at/wmts/1.0.0/WMTSCapabilities.
xml,layer=lb" wmts.xml -of WMTS
Now, what about TMS services in geoserver? Is it possible to create the XML
files using gdal_tranlate for a TMS capabilities request as in "
http://localhost:8080/geoserver/gwc/service/tms/1.0.0/"? If so, how to
that for a specific layer?
Thank you for your time in advance
Kind Regards
Julierme
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180222/3d929984/attachment.html>
