[gdal-dev] Constructing GDAL_WMS XML files for TMS servers
Even Rouault even.rouault at spatialys.com
Thu Feb 22 09:10:49 PST 2018
On jeudi 22 février 2018 12:17:39 CET Julierme Pinheiro wrote:
> Hi all,
> I found this discussion related to my question: http://osgeo-org.1560.x6.
> nabble.com/gdal-dev-Constructing-GDAL-WMS-XML-files-for-TMS-servers-
> td5033787.html.
> I have several sar images in geoserver and I need to create a XML file for
> each TMS service in order to load them in Qgis.
> For the wmts services I used the folowing gdal function:
> gdal_translate "WMTS:http://maps.wien.gv.at/wmts/1.0.0/WMTSCapabilities.
> xml,layer=lb" wmts.xml -of WMTS
> Now, what about TMS services in geoserver? Is it possible to create the XML
> files using gdal_tranlate for a TMS capabilities request as in "
> http://localhost:8080/geoserver/gwc/service/tms/1.0.0/"? If so,  how to
> that for a specific layer?
I haven't a GeoServer installation handy, but normally something like
gdal_translate -of WMS http://localhost:8080/geoserver/gwc/service/tms/1.0.0/{layername} tms.xml
should work
You may need to modify the URL such that it points to a XML document whose root element is <TileMap>
If you do
gdalinfo  http://localhost:8080/geoserver/gwc/service/tms/1.0.0
it should list all the layers as subdatasets
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180222/98f46c7b/attachment.html>
