[gdal-dev] gdal-dev Digest, Vol 164, Issue 23
Rasika Chinchwade rasikachinchwade31 at gmail.com
Tue Jan 16 23:28:19 PST 2018
Thank you sir for your reply.Still I am not getting the problem.I followed
the steps suggested. Though it is not giving error but also not converting
the file into proper projection system,after observing the parameters of
output tiff file its
protection system is Arbitrary(pixel based)
resloution is 0.12x0.12 Degrees
Datum:unkown
UL map:0.843,81.042
Instead of this I want projection system Geographic Lat/long
pixel size: 0.04x0.04 degrees as this datasets having 4km resloution
Datum:WGS-1984
Kindly tell me how I can do this.
thank you
On Wed, Jan 17, 2018 at 1:30 AM, <gdal-dev-request at lists.osgeo.org> wrote:
> Send gdal-dev mailing list submissions to
>         gdal-dev at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
>         https://lists.osgeo.org/mailman/listinfo/gdal-dev
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>         gdal-dev-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of gdal-dev digest..."
> Today's Topics:
>    1. Re: GDALWARP Error (Andre Joost)
>    2. Re: Resulting geometry from OGRGeometry::difference somehow
>       got simplified (mikeucfl)
> Message: 1
> Date: Tue, 16 Jan 2018 15:30:34 +0100
> From: Andre Joost <andre+joost at nurfuerspam.de>
> To: gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] GDALWARP Error
> Message-ID: <p3l2f1$u6n$1 at blaine.gmane.org>
> Content-Type: text/plain; charset=utf-8; format=flowed
> Am 16.01.18 um 14:24 schrieb Rasika Chinchwade:
> > Please find attachment of files
> >   3DIMG_01JAN2018_0000_L3B_HEM_DLY.h5
> > <https://drive.google.com/file/d/1ToPqBu4Gnw4DfXZCMkBBO675mfP_
> R6I3/view?usp=drive_web>
> >   3DIMG_01JAN2018_0130_L2B_LST.h5
> > <https://drive.google.com/file/d/1QmvrYxhIpI2ks-
> OsSlBpuDpO7eLbQPjF/view?usp=drive_web>
> It works for me with the last 4 commands given in
> https://gis.stackexchange.com/questions/253884/projecting-
> insat3d-l1b-data-from-hdf5-to-geotiff
> Note that you have to edit the mir.vrt file with the Geolocation section
> in the answer to
> https://gis.stackexchange.com/questions/154339/unable-to-warp-hdf5-files:
> <metadata domain="GEOLOCATION">
>       <mdi key="X_DATASET">lon.vrt</mdi>
>       <mdi key="X_BAND">1</mdi>
>       <mdi key="Y_DATASET">lat.vrt</mdi>
>       <mdi key="Y_BAND">1</mdi>
>       <mdi key="PIXEL_OFFSET">0</mdi>
>       <mdi key="LINE_OFFSET">0</mdi>
>       <mdi key="PIXEL_STEP">1</mdi>
>       <mdi key="LINE_STEP">1</mdi>
>     </metadata>
> I removed the GCP section of the mir.vrt file, and there is no error
> message anymore.
> HTH,
> Andre Joost
> Message: 2
> Date: Tue, 16 Jan 2018 12:44:34 -0700 (MST)
> From: mikeucfl <mikeucfl at gmail.com>
> Subject: Re: [gdal-dev] Resulting geometry from
>         OGRGeometry::difference somehow got simplified
> Message-ID: <1516131874684-0.post at n6.nabble.com>
> Content-Type: text/plain; charset=us-ascii
> Got permission to show the actual data:
> <http://osgeo-org.1560.x6.nabble.com/file/t381880/RUklfeY.png>  (left side
> is what the data should look like, red is what the data looks like after
> calling the difference operation).
> Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
> Subject: Digest Footer
> End of gdal-dev Digest, Vol 164, Issue 23
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180117/2ab0bd48/attachment.html>
