[gdal-dev] Opening a folder of shape files with different encoding as a data set
Lauri Kajan lauri.kajan at gmail.com
Wed Jan 17 00:42:46 PST 2018
Hi all,
Is it possible to define shape file encoding per layer when reading a
folder/zip as a data set?
My current code reads a zip file containing shape files as a data set and
then iterates containing layers. The problem I have is that the data
provider changed their release so that shape files in zip may use different
encoding.
Do I have any other solutions than opening each shape file separately?
Thanks,
-Lauri
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180117/e381cbd4/attachment.html>
