[gdal-dev] symbol lookup error in libgdal.so.20 on conda through windows subsystem for linux
Sam Franklin
mr.samfranklin at gmail.com
Wed Jan 31 08:56:56 PST 2018
Hey Sean. Okay many thanks. Will take it up with the conda-forge people. as
you suggest. Thanks, S
Sam Franklin
On 31 January 2018 at 16:23, Sean Gillies <sean at mapbox.com> wrote:
> Hi Sam,
> I don't know how to resolve the issue. There may be some clues in the
> conda-forge GDAL tracker: https://github.com/conda-
> forge/gdal-feedstock/issues and it would be worth making a new issue
> there if it isn't a known and fixed bug. The conda-forge team is quick to
> patch and update their packages.
> On Wed, Jan 31, 2018 at 4:50 AM, Sam Franklin <mr.samfranklin at gmail.com>
> wrote:
>> Hey List. Sorry to disturb. I came across this symbol error when trying
>> to use several gdal binaries within a conda environment on the Windows 10
>> Subsystem for Linux. Looks like possible linking error which I can't seem
>> to resolve.
>> ### The error
>> $ gdalinfo
>> gdalinfo: symbol lookup error: /home/sam/anaconda2/envs/py36/bin/../lib/libgdal.so.20:
>> undefined symbol: _ZN11xercesc_3_211InputSource11setEncodingEPKt
>> $ gdal_translate --version
>> gdal_translate: symbol lookup error: /home/sam/anaconda2/envs/py36/bin/../lib/libgdal.so.20:
>> ### my environment
>> I set up a clean conda python 3.6 environment with:
>> $ conda create --name py36 python=3.6
>> $ conda install -c conda-forge gdal
>> $ conda list
>> gdal 2.2.3 py36_0 conda-forge
>> libgdal 2.2.3 3 conda-forge
>> $ conda info
>> active environment : py36
>> conda version : 4.4.7
>> platform : linux-64
>> ## Other useful info:
>> $ gdal-config --libs
>> -L/home/sam/anaconda2/envs/py36/lib -lgdal
>> $ gdal-config --cflags
>> -I/home/sam/anaconda2/envs/py36/include
>> I got round this by simply running conda on windows 10 which does not
>> encounter the above symbol error.
>> Thought I'd let the list know and if anyone had any ideas on how to
>> resolve?
>> Thanks in advance.
>> Sam Franklin
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> Sean Gillies
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180131/7e6c8744/attachment.html>
