[gdal-dev] symbol lookup error in libgdal.so.20 on conda through windows subsystem for linux
Sean Gillies sean at mapbox.com
Wed Jan 31 08:23:59 PST 2018
Hi Sam,
I don't know how to resolve the issue. There may be some clues in the
conda-forge GDAL tracker:
https://github.com/conda-forge/gdal-feedstock/issues and it would be worth
making a new issue there if it isn't a known and fixed bug. The conda-forge
team is quick to patch and update their packages.
On Wed, Jan 31, 2018 at 4:50 AM, Sam Franklin <mr.samfranklin at gmail.com>
wrote:
> Hey List. Sorry to disturb. I came across this symbol error when trying to
> use several gdal binaries within a conda environment on the Windows 10
> Subsystem for Linux. Looks like possible linking error which I can't seem
> to resolve.
> ### The error
> $ gdalinfo
> gdalinfo: symbol lookup error: /home/sam/anaconda2/envs/py36/bin/../lib/libgdal.so.20:
> undefined symbol: _ZN11xercesc_3_211InputSource11setEncodingEPKt
> $ gdal_translate --version
> gdal_translate: symbol lookup error: /home/sam/anaconda2/envs/py36/bin/../lib/libgdal.so.20:
> ### my environment
> I set up a clean conda python 3.6 environment with:
> $ conda create --name py36 python=3.6
> $ conda install -c conda-forge gdal
> $ conda list
> gdal                      2.2.3                    py36_0    conda-forge
> libgdal                   2.2.3                         3    conda-forge
> $ conda info
> active environment : py36
> conda version : 4.4.7
> platform : linux-64
> ## Other useful info:
> $ gdal-config --libs
> -L/home/sam/anaconda2/envs/py36/lib -lgdal
> $ gdal-config --cflags
> -I/home/sam/anaconda2/envs/py36/include
> I got round this by simply running conda on windows 10 which does not
> encounter the above symbol error.
> Thought I'd let the list know and if anyone had any ideas on how to
> resolve?
> Thanks in advance.
> Sam Franklin
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Sean Gillies
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180131/aff5ac0f/attachment.html>
