[gdal-dev] Reading remote jp2k files
Even Rouault
even.rouault at spatialys.com
Wed Jul 25 09:00:23 PDT 2018
Matt,
> I'm having trouble reading JP2K files remotely. I originally ran into this
> problem when trying to use remote Sentinel-2 files as input to the GDAL
> Warp API in C++. It works when I use a local version of the file.
> I'm not sure if this is supported behavior, I thought it was, but to test I
> tried gdal_translate on a remote file, and one with the local file.
> $ gdal_translate
> https://sentinel-s2-l1c.s3.amazonaws.com/tiles/32/T/QR/2018/1/21/0/B04.jp2
> sentinel-test-remote.tif -f GTiff
> $ gdal_translate B03.jp2 sentinel-test-local.tif -f GTiff
> The local file works fine, but when using the remote file gdal_translate
> just crashes with no error message.
A process crash ? Can you get a stack trace / valgrind output ?
I tried, and it failed in a regular way, since when you use http:// the HTTP
driver triggers. This driver downloads the whole file in memory before passing
it to the real driver, and it deleted the temp file, whereas the JP2OpenJPEG
driver needs to be able to re-open it. Just fixed that issue
> I'm using GDAL 2.3.1 with openjpeg 2.3, I'm using a docker image
> developmentseed/geolambda:1.0.0 and you can see the Dockerfile here:
> https://github.com/developmentseed/geolambda/blob/master/Dockerfile
> Is this supported behavior, should I be able to read these files remotely,
> and do windowed reads on them?
For windowed reads, you need to prefix with /vsicurl/, but I don't guarantee
the efficiency of this with JPEG2000 in general, and with JP2OpenJPEG in
particular.
Even
http://www.spatialys.com
