[gdal-dev] mosaiced SAR in geotiff
Gong, Shawn
SGONG at mdacorporation.com
Fri Jul 27 13:10:11 PDT 2018
Hi list,
I have simulated RCM Complex SLC in mosaiced geotiff format that I don't know how to deal with.
Is there a driver for it, similar to SPOT7 mosaiced product?
I tried to use gdalbuildvrt and gdal_merge but neither worked because the mosaiced geotiff are not georeferenced. Each chip has only 4 corner GCPs.
Should I use set_geotransform( ), then gdalbuildvrt ?
gdalinfo output:
Driver: GTiff/GeoTIFF
Files: PGS_TD_PR_GenIm_MRes30_1_PT_1_HH_0.tif
Size is 2407, 291
Coordinate System is `'
GCP Projection =
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4326"]]
GCP[ 0]: Id=1, Info=
(0.5,0.5) -> (-21.411272470412,-80.7062573860622,0)
GCP[ 1]: Id=2, Info=
(2406.5,0.5) -> (-21.4712880925672,-80.4068317341721,0)
GCP[ 2]: Id=3, Info=
(2406.5,290.5) -> (-21.1149325668978,-80.4046874263347,0)
GCP[ 3]: Id=4, Info=
(0.5,290.5) -> (-21.0437603692169,-80.7040392737628,0)
Metadata:
AREA_OR_POINT=Area
TIFFTAG_DATETIME=2018:04:05 17:40:44
TIFFTAG_IMAGEDESCRIPTION=HH
Image Structure Metadata:
INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0, 291.0)
Upper Right ( 2407.0, 0.0)
Lower Right ( 2407.0, 291.0)
Center ( 1203.5, 145.5)
Band 1 Block=2407x217 Type=Int16, ColorInterp=Gray
Band 2 Block=2407x217 Type=Int16, ColorInterp=Undefined
**.tif.tiffinfo:
TIFF Directory at offset 0x3fc280 (4178560)
Image Width: 2407 Image Length: 291
Bits/Sample: 16
Sample Format: signed integer
Compression Scheme: None
Photometric Interpretation: min-is-black
Orientation: row 0 top, col 0 lhs
Samples/Pixel: 2
Rows/Strip: 217
Planar Configuration: single image plane
ImageDescription: HH
DateTime: 2018:04:05 17:40:44
--GeoTIFF Tags--
Geo Tiepoints:
( 0.500000 0.500000 0.000000)->( -21.411272 -80.706257 0.000000)
( 2406.500000 0.500000 0.000000)->( -21.471288 -80.406832 0.000000)
( 2406.500000 290.500000 0.000000)->( -21.114933 -80.404687 0.000000)
( 0.500000 290.500000 0.000000)->( -21.043760 -80.704039 0.000000)
GeoKey Directory:(present)
GeoKey Double Params:(present)
GeoKey ASCII Parameters:(present)
**.tif.listgeo:
Geotiff_Information:
Version: 1
Key_Revision: 1.0
Tagged_Information:
ModelTiepointTag (8,3):
0.5 0.5 0
-21.411272470412 -80.70625738606220
2406.5 0.5 0
-21.4712880925672-80.40683173417210
2406.5 290.5 0
-21.1149325668978-80.40468742633470
0.5 290.5 0
-21.0437603692169-80.70403927376280
End_Of_Tags.
Keyed_Information:
GTModelTypeGeoKey (Short,1): ModelTypeGeographic
GTRasterTypeGeoKey (Short,1): RasterPixelIsArea
GTCitationGeoKey (Ascii,27): "Uncorrected Satellite Data"
GeographicTypeGeoKey (Short,1): GCS_WGS_84
GeogCitationGeoKey (Ascii,6): "WGS84"
GeogGeodeticDatumGeoKey (Short,1): Datum_WGS84
GeogLinearUnitsGeoKey (Short,1): Linear_Meter
GeogAngularUnitsGeoKey (Short,1): Angular_Degree
GeogEllipsoidGeoKey (Short,1): Ellipse_WGS_84
GeogSemiMajorAxisGeoKey (Double,1): 6378137
GeogSemiMinorAxisGeoKey (Double,1): 6356752.31424518
End_Of_Keys.
End_Of_Geotiff.
GCS: 4326/WGS 84
Datum: 6326/World Geodetic System 1984
Ellipsoid: 7030/WGS 84 (6378137.00,6356752.31)
Prime Meridian: 8901/Greenwich (0.000000/ 0d 0' 0.00"E)
Corner Coordinates:
... unable to transform points between pixel/line and PCS space
Thanks,
Shawn
This electronic correspondence, including any attachments, is intended solely for the use of the intended recipient(s) and may contain legally privileged, proprietary and/or confidential information. If you are not the intended recipient, please immediately notify the sender by reply e-mail and permanently delete all copies of this electronic correspondence and associated attachments. Any use, disclosure, dissemination, distribution or copying of this electronic correspondence and any attachments for any purposes that have not been specifically authorized by the sender is strictly prohibited.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180727/f1ef59a2/attachment.html>
