[gdal-dev] Area from gdalinfo metadata on a .tif image
Andrew C Aitchison
andrew at aitchison.me.uk
Thu Jul 26 07:23:57 PDT 2018
On Thu, 26 Jul 2018, Tyler Burse wrote:
> I hope you all have had a great week so far. I am hoping you will be able
> to provide some help because I have not been able to find a way to get the
> area from the metadata returned by gdalinfo. What I get as the return of
> gdalinfo appears to be a non-georeferenced figure such as:
> C:\Temp>gdalinfo figure1.tif
> Driver: GTiff/GeoTIFF
> Files: figure1.tif
> Size is 244, 210
> Coordinate System is `'
> Metadata:
> TIFFTAG_XRESOLUTION=96
> TIFFTAG_YRESOLUTION=96
> TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
> Image Structure Metadata:
> INTERLEAVE=PIXEL
> Corner Coordinates:
> Upper Left ( 0.0, 0.0)
> Lower Left ( 0.0, 210.0)
> Upper Right ( 244.0, 0.0)
> Lower Right ( 244.0, 210.0)
> Center ( 122.0, 105.0)
> Band 1 Block=244x11 Type=Byte, ColorInterp=Red
> Band 2 Block=244x11 Type=Byte, ColorInterp=Green
> Band 3 Block=244x11 Type=Byte, ColorInterp=Blue
> Would you be able to help me with finding the best way to extract the area
> in kilometers squared from this info using GDAL?
The output includes
so, formally, we do not know the relationship between the image and the
piece of the earth that it represents.
If the file specified the coordinate system,
then gdalinfo would report something like:
Coordinate System is:
PROJCS["OSGB 1936 / British National Grid",
GEOGCS["OSGB 1936",
DATUM["OSGB_1936",
SPHEROID["Airy 1830",6377563.396,299.3249646,
AUTHORITY["EPSG","7001"]],
TOWGS84[446.448,-125.157,542.06,0.15,0.247,0.842,-20.489],
AUTHORITY["EPSG","6277"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9122"]],
AUTHORITY["EPSG","4277"]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",49],
PARAMETER["central_meridian",-2],
PARAMETER["scale_factor",0.9996012717],
PARAMETER["false_easting",400000],
PARAMETER["false_northing",-100000],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]],
AXIS["Easting",EAST],
AXIS["Northing",NORTH],
AUTHORITY["EPSG","27700"]]
Origin = (-649749.999999999883585,1449750.000000000465661)
Pixel Size = (500.000000000000000,-500.000000000000171)
Metadata:
Corner Coordinates:
Upper Left ( -649750.000, 1449750.000) ( 21d55'22.41"W, 61d27'54.60"N)
Lower Left ( -649750.000, -150250.000) ( 16d 0'12.44"W, 47d41'10.18"N)
Upper Right ( 1350250.000, 1449750.000) ( 16d 9' 2.77"E, 61d43'17.34"N)
Lower Right ( 1350250.000, -150250.000) ( 10d42'41.48"E, 47d50'21.53"N)
Note the lines:
UNIT["metre",1,
- so this coordinate system and file is in metres (other commone coordinate systems use US feet or degrees as units).
This file represents a space on the ground which is
1320250 - -649750 = 2000000m = 2000km east to west, and
1449750 - -150250 = 1600000m = 1600km north to south,
so has an area of 3.2million km^2.
Andrew C. Aitchison Cambridge, UK
