[gdal-dev] RasterIO support for zlib / deflate compression?
Even Rouault
even.rouault at spatialys.com
Sun Jun 3 03:41:07 PDT 2018
Brad,
> I've been looking at how much work it might take to implement a new NITF
> compression value (IC=CC and IC=MC) which is basically just ZLIB DEFLATE
> encoded blocks.
Is it your own codec or something already standardized in NITF ?
If the former, I'd suggest that you consider ZStandard [1] compression
instead. It performs much better than ZLIB Deflate. I've integrated it
recently as a TIFF codec
> Before I start to dig around in zlib, is there any support in the RasterIO
> level to do this? Anything else I could copy before reimplementing it
> poorly?
Nothing at the RasterIO() level that exposes compressed datastream.
For ZLib(), there's a tiny helper, CPLZLibDeflate(), that can help you a bit.
Even
[1] https://github.com/facebook/zstd
http://www.spatialys.com
