[gdal-dev] Convert VRT+JPEG with gdalwarp
kalevj kalev.julge at reach-u.com
Thu Jun 21 07:00:03 PDT 2018
Hello,
I used gdalwarp to transform a VRT+JPEG pair from one EPSG projection to
another. Everything worked well. This conversion changed the VRT file so
that reprojection takes place when the images are loaded. However, I would
need to reproject the JPEG so that there would not be a need to reproject
every time the images are loaded. Is it possible somehow?
I used the command:
"gdalwarp -s_srs EPSG:2006 -t_srs EPSG:3857 -of VRT -r near old.vrt new.vrt"
Thanks!
Kalev
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
