[gdal-dev] [EXTERNAL] Convert VRT+JPEG with gdalwarp
Doug Newcomb doug_newcomb at fws.gov
Thu Jun 21 07:24:09 PDT 2018
Kalev,
Just set the output file format to -f  JPEG format   ( .jpg) or  -f
JP2OpenJPEG (.jp2)
The JPEG format will be lossey by default.  Is that what you want?
See:
https://medium.com/planet-stories/a-gentle-introduction-to-gdal-part-1-a3253eb96082
https://medium.com/planet-stories/a-gentle-introduction-to-gdal-part-2-map-projections-gdalwarp-e05173bd710a
Doug
On Thu, Jun 21, 2018 at 10:00 AM kalevj <kalev.julge at reach-u.com> wrote:
> Hello,
> I used gdalwarp to transform a VRT+JPEG pair from one EPSG projection to
> another. Everything worked well. This conversion changed the VRT file so
> that reprojection takes place when the images are loaded. However, I would
> need to reproject the JPEG so that there would not be a need to reproject
> every time the images are loaded. Is it possible somehow?
> I used the command:
> "gdalwarp -s_srs EPSG:2006 -t_srs EPSG:3857 -of VRT -r near old.vrt
> new.vrt"
> Thanks!
> Kalev
> Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Doug Newcomb
USFWS
551F Pylon Dr
Raleigh, NC
919-856-4520 ext. 14 doug_newcomb at fws.gov
*NOTE: This email correspondence and any attachments to and from this
sender is subject to the Freedom of Information Act (FOIA) and may be
disclosed to third parties.*​
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180621/606eac75/attachment.html>
