[gdal-dev] PROJ 5.0.0
Kurt Schwehr
schwehr at gmail.com
Thu Mar 1 11:56:47 PST 2018
Anyone taken a look at PROJ since Sept? I've tried a little bit to get it
working for me, but I get memory leaks.
Took a bit of a look here:
https://kbevers.github.io/development/migration.html
My feeble attempt is here:
https://gist.github.com/schwehr/94f4501206363cf83362a2eac2898f7b
I was building staticly on debian testing and the leak sanitizer was very
unhappy with
https://github.com/schwehr/gdal-autotest2/blob/master/cpp/ogr/ogr_srs_proj4_test.cc
Direct leak of 648 byte(s) in 1 object(s) allocated from:
#0 0x55cc91c17533 in malloc
third_party/llvm/llvm/projects/compiler-rt/lib/asan/asan_malloc_linux.cc:88:3
#1 0x7fe2ea999ac1 in pj_malloc
third_party/proj4/proj/src/pj_malloc.c:78:17
#2 0x7fe2ea999b35 in pj_calloc
third_party/proj4/proj/src/pj_malloc.c:93:17
#3 0x7fe2ea9a4c3d in pj_utm
third_party/proj4/proj/src/proj_etmerc.c:395:5
#4 0x7fe2ea993bb3 in pj_init_ctx
third_party/proj4/proj/src/pj_init.c:521:11
#5 0x7fe2ea993382 in pj_init_plus_ctx
third_party/proj4/proj/src/pj_init.c:412:14
#6 0x7fe2ec7b7a26 in OCTProj4NormalizeInternal(char const*)
third_party/gdal/ogr/ogrct.cpp:328:22
#7 0x7fe2ec7b7824 in OCTProj4Normalize
third_party/gdal/ogr/ogrct.cpp:357:16
#8 0x7fe2ec793a5e in OGRSpatialReference::importFromProj4(char const*)
third_party/gdal/ogr/ogr_srs_proj4.cpp:512:27
followed by a pile of indirect leaks with pretty much the same call stack
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180301/d0816ca2/attachment.html>
