[gdal-dev] Questions / clarification about 'FDO Geometry Format' and creation of GeoPackage Vectors
Mark Johnson
mj10777 at googlemail.com
Fri Mar 2 22:36:46 PST 2018
'FDO Geometry Format':
Am I reading the code correctly that 'FDO', at least in the case of a
Sqlite-Container, is read only?
GeoPackage-Vector creation with ogr2ogr:
That it not possible to retain the original Geometry-Column Name, but
either 'geom' of the value given with '-lco GEOMETRY_NAME=geometry_name'
for all geometries.
That a subset of specific Tables is not possible, but only all Tables.
If it is possible (through the usage of 'sql='), could a pratical sample be
added to:
http://www.gdal.org/drv_geopackage.html
Mark
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180303/8a177871/attachment.html>
