[gdal-dev] Call for discussion for RFC 71: Migration to GitHub
Mateusz Loskot mateusz at loskot.net
Mon Mar 19 14:25:20 PDT 2018
On 19 March 2018 at 22:17, Even Rouault <even.rouault at spatialys.com> wrote:
>> "Most visible Trac wiki documentation will have to be revised to point
>> to GitHub?"
> I meant everywhere we mention svn, we should point to git/github.
>> I think, this means the content is copied to GitHub wiki.
> I've not given any thoughts about that right now. I excluded it from the scope
> of this RFC (see "not covered by this RFC section") so as to keep focused on
> the most minimum set of things needed to have a github-based workflow for code
> changes & ticket management.
Even,
Sorry, I must have misunderstood those points.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
