[gdal-dev] gdal_translate: adding a gcp_file parameter useful?
Mark Johnson mj10777 at googlemail.com
Thu May 10 18:51:36 PDT 2018
Would adding a '-gcp_file' as a input parameter, that would contain the
list of gcp's to be used, be considered useful?
Often the gcp list could be created programmaticly and saved to file, which
would simplify the use from a script.
Mark
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180511/bd2b90cf/attachment.html>
