[gdal-dev] gdal_translate: adding a gcp_file parameter useful?
jratike80
jukka.rahkonen at maanmittauslaitos.fi
Fri May 11 00:04:42 PDT 2018
mj10777 wrote
> Would adding a '-gcp_file' as a input parameter, that would contain the
> list of gcp's to be used, be considered useful?
> Often the gcp list could be created programmaticly and saved to file,
> which
> would simplify the use from a script.
> Mark
Have you tried the generic --optfile option
http://www.gdal.org/gdal_utilities.html?
-Jukka Rahkonen-
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
