[gdal-dev] gdal_merge.py not executing or found
Dmitry Baryshnikov
bishop.dev at gmail.com
Wed Nov 7 07:14:29 PST 2018
Hi Jeremy,
You can install QGIS with GDAL and python bindings using alternative
installer by NextGIS (http://nextgis.com/nextgis-qgis/).
GDAL python bindings working, gdal_merge also included.
This is previous QGIS LTR release 2.18.25, but with fresh GDAL 2.3.2 and
other libraries. This installation should not affect you current QGIS
install, but I'm not sure about the opposite.
Best regards,
Dmitry
07.11.2018 17:55, Jeremy Salerno пишет:
> Thanks for the help Even.
> Is there a simple way to check if the python bindings are installed? I
> installed GDAL through the QGIS installer. I tried running gdal_merge.py
> after downloading the file from github and have had no success.
> Jeremy A. Salerno
> Weston Geophysical Corp.
> 181 Bedford St. Suite #1
> Lexington, MA. 02420
> jsalerno at westongeo.com
> *www.westongeophysical.com* <http://www.westongeophysical.com>
> On Wed, Nov 7, 2018 at 9:28 AM Even Rouault <even.rouault at spatialys.com>
> wrote:
>> Jeremy,
>>> I cannot even find the gdal_merge.py file in
>>> /Library/Frameworks/GDAL.framework/Versions/Current/Programs/ or anywhere
>>> else in the gdal framework directory.
>> Should be reported to the creator of the package. I believe this is
>> William Kyngesburye (CC'ed) but I'm not completely sure.
>>> I looked to see if I could install
>>> the .py file separately but can't find any installation options on the
>> GDAL
>>> website.
>> You can always download the script from
>> https://github.com/OSGeo/gdal/blob/master/gdal/swig/python/scripts/gdal_merge.py
>> (assuming that the GDAL Python bindings are installed)
>> Even
>> Spatialys - Geospatial professional services
>> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20181107/c6c498c1/attachment.html>
