[gdal-dev] gdal_merge.py not executing or found
Jeremy Salerno
jsalerno at westongeo.com
Wed Nov 7 06:55:28 PST 2018
Thanks for the help Even.
Is there a simple way to check if the python bindings are installed? I
installed GDAL through the QGIS installer. I tried running gdal_merge.py
after downloading the file from github and have had no success.
Jeremy A. Salerno
Weston Geophysical Corp.
181 Bedford St. Suite #1
Lexington, MA. 02420
*www.westongeophysical.com* <http://www.westongeophysical.com>
On Wed, Nov 7, 2018 at 9:28 AM Even Rouault <even.rouault at spatialys.com>
wrote:
> Jeremy,
> > I cannot even find the gdal_merge.py file in
> > /Library/Frameworks/GDAL.framework/Versions/Current/Programs/ or anywhere
> > else in the gdal framework directory.
> Should be reported to the creator of the package. I believe this is
> William Kyngesburye (CC'ed) but I'm not completely sure.
> > I looked to see if I could install
> > the .py file separately but can't find any installation options on the
> GDAL
> > website.
> You can always download the script from
> https://github.com/OSGeo/gdal/blob/master/gdal/swig/python/scripts/gdal_merge.py
> (assuming that the GDAL Python bindings are installed)
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20181107/95d456c6/attachment.html>
