[gdal-dev] adding a new method to OGRFieldDefn & gdalautotest
Even Rouault even.rouault at spatialys.com
Wed Nov 7 12:19:34 PST 2018
On mercredi 7 novembre 2018 19:56:10 CET Alan Stewart wrote:
> Thanks, Even, I certainly didn't read the file header. After making all your
> suggested changes the compiler is erroring on
> swig/python/extensions/gdal_wrap.cpp, which I have not touched.
> I notice it is using " Visual C++ for Python", version 9.0. Is that the
> correct compiler to use?
In theory, yes, but in practice you can force the use of your current MSVC
version and it happens to work just fine, by setting the following env
variables
set DISTUTILS_USE_SDK=1
set MSSdk=1
http://www.spatialys.com
