[gdal-dev] gdal_merge.py not executing or found
Jeremy Salerno
jsalerno at westongeo.com
Wed Nov 7 05:06:00 PST 2018
Hi All,
When I type gdal_merge.py into Terminal, the output is -bash:
gdal_merge.py: command not found.
I installed 3.4.0 Madeira [from this link] for macOS 10.13 (
https://www.qgis.org/en/site/forusers/download), which came with a gdal
installer.
I cannot even find the gdal_merge.py file in
/Library/Frameworks/GDAL.framework/Versions/Current/Programs/ or anywhere
else in the gdal framework directory. I looked to see if I could install
the .py file separately but can't find any installation options on the GDAL
website.
Thanks!
Jeremy
Jeremy A. Salerno
Weston Geophysical Corp.
181 Bedford St. Suite #1
Lexington, MA. 02420
*www.westongeophysical.com* <http://www.westongeophysical.com>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20181107/98cb0af8/attachment-0001.html>
