[gdal-dev] Projection error messages when warping from worldwide to local projection
Even Rouault
even.rouault at spatialys.com
Fri Nov 9 06:27:16 PST 2018
Salut Thomas,
I don't get any warning with GDAL 2.3.2 and PROJ 5.1.0. While investigating, I
found this is due to the use of the PROJ 5 transformation API that doesn't
emit an error when an out of domain situation happens when transforming a
single point (wheras PROJ 4 did), but just returning a HUGE_VAL value.
Even
http://www.spatialys.com
