[gdal-dev] Projection error messages when warping from worldwide to local projection
thomas bonfort
thomas.bonfort at gmail.com
Fri Nov 9 06:50:19 PST 2018
Salut Even,
Thanks for the quick answer. Sorry I forgot to mention I was using gdal
2.3.2 and proj 4.9.3. I'll upgrade to 5.1.0!
Regards,
Thomas
On Fri, Nov 9, 2018 at 3:27 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> Salut Thomas,
> I don't get any warning with GDAL 2.3.2 and PROJ 5.1.0. While
> investigating, I
> found this is due to the use of the PROJ 5 transformation API that doesn't
> emit an error when an out of domain situation happens when transforming a
> single point (wheras PROJ 4 did), but just returning a HUGE_VAL value.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20181109/8c69b843/attachment.html>
