[gdal-dev] GML element/attribute discovery inconsistency
Even Rouault even.rouault at spatialys.com
Tue Nov 27 03:46:37 PST 2018
> Are my observations correct?
Björn,
It would be difficult to deny the results of tests :-)
The GML driver has a lot of particular handling tailored for particular
datasets, which makes understanding its behaviour non-obvious
From the code (which confirms your observations),
- if an element has a xsi:nil attribute, then its other attributes are ignored
and the content of the element is set to NULL (what you observe with a1)
- there is a particular case for the uom attribute, which is always reported
even if GML_ATTRIBUTES_TO_OGR_FIELDS is not set (the _uom case was added
before the generalization of GML_ATTRIBUTES_TO_OGR_FIELDS)
- empty elements (if empty for all features) are not reported as OGR fields
You may want to try the GMLAS driver for something that involves less
guessing. The GML driver can work without any schema, and if the schema is
present only supports simple constructs in it. Contrary to the GMLAS driver,
which is (almost) completely schema driven to create the OGR layer and
attribute structure:
https://www.gdal.org/drv_gmlas.html
Even
http://www.spatialys.com
