[gdal-dev] GML element/attribute discovery inconsistency
jratike80
jukka.rahkonen at maanmittauslaitos.fi
Tue Nov 27 03:57:01 PST 2018
I would mention also an open option EMPTY_AS_NULL=NO that seems to adds some
fields into ogrinfo result:
gml_id: String (0.0) NOT NULL
a1: StringList (0.0)
a2: String (0.0)
a2_uom: String (1.0)
a3_title: String (5.0)
a3: String (0.0)
a3_href: String (22.0)
a4: String (0.0)
a4_href: String (40.0)
a5: String (0.0)
OGRFeature(MyFeaturetype1):785667386
gml_id (String) = id.8685d1b8-a851-4034-b8ed-a4c785667386
a1 (StringList) = (null)
a2 (String) =
a2_uom (String) = m
a3_title (String) = title
a3 (String) =
a3_href (String) = https://test.com/value
a4 (String) =
a4_href (String) = #id.8685d1b8-a851-4034-b8ed-a4c785667386
a5 (String) =
-Jukka Rahkonen-
Even Rouault-2 wrote
>> Are my observations correct?
> Björn,
> It would be difficult to deny the results of tests :-)
> The GML driver has a lot of particular handling tailored for particular
> datasets, which makes understanding its behaviour non-obvious
> From the code (which confirms your observations),
> - if an element has a xsi:nil attribute, then its other attributes are
> ignored
> and the content of the element is set to NULL (what you observe with a1)
> - there is a particular case for the uom attribute, which is always
> reported
> even if GML_ATTRIBUTES_TO_OGR_FIELDS is not set (the _uom case was added
> before the generalization of GML_ATTRIBUTES_TO_OGR_FIELDS)
> - empty elements (if empty for all features) are not reported as OGR
> fields
> You may want to try the GMLAS driver for something that involves less
> guessing. The GML driver can work without any schema, and if the schema is
> present only supports simple constructs in it. Contrary to the GMLAS
> driver,
> which is (almost) completely schema driven to create the OGR layer and
> attribute structure:
> https://www.gdal.org/drv_gmlas.html
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at .osgeo
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
