[gdal-dev] HDF data mis-applied sinusoidal
Michael Sumner
mdsumner at gmail.com
Thu Nov 29 12:31:26 PST 2018
Hello, these data in HDF4 format are interpreted as being in sinusoidal
projection, I guess some conflation with the MODIS logic about some
products (?).
ftp://ftp.glcf.umd.edu/glcf/GLASS/ABD/MODIS/0.05D/2013/
Particular file is here, but note there's also an auxiliarly .hdf.xml with
it:
ftp://ftp.glcf.umd.edu/glcf/GLASS/ABD/MODIS/0.05D/2013/GLASS02B06.V04.A2013169.2017128.hdf
A plot of the first subdataset shows that it is trivially in regular
longlat (or eqc), the gdalinfo output is below.
I'd appreciate any insights into why this is interpreted this way, and
whether the GDAL detection logic could be improved - or whether the data
providers need to update the internal metadata.
Cheers, Mike.
gdalinfo --version GDAL 2.3.2, released 2018/09/21
gdalinfo
HDF4_EOS:EOS_GRID:"GLASS02B06.V04.A2013169.2017128.hdf":GLASS02B06:ABD_BSA_VIS
Driver: HDF4Image/HDF4 Dataset
Files: GLASS02B06.V04.A2013169.2017128.hdf
Size is 7200, 3600
Coordinate System is:
PROJCS["unnamed",
GEOGCS["Unknown datum based upon the custom spheroid",
DATUM["Not specified (based on custom spheroid)",
SPHEROID["Custom spheroid",6371007.181,0]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]],
PROJECTION["Sinusoidal"],
PARAMETER["longitude_of_center",0],
PARAMETER["false_easting",0],
PARAMETER["false_northing",0],
UNIT["Meter",1]]
Origin = (-20015109.353999998420477,10007554.676999999210238)
Pixel Size = (154.437572175972150,-308.875144351944300)
Metadata:
add_offset=0
add_offset_err=0
ASSOCIATEDINSTRUMENTSHORTNAME.1=AVHRR
ASSOCIATEDPLATFORMSHORTNAME.1=NOAA
ASSOCIATEDSENSORSHORTNAME.1=AVHRR
BANDDEFINITION=Surface
CHARACTERISTICBINSIZE=926.6
DATACOLUMNS=7200
DATAROWS=3600
DATASETNAME=GLASS02B06
DAYNIGHTFLAG=Both
EASTHBOUNDINGCOORDINATE=180
EXCLUSIONGRINGFLAG=N
GLOBALGRIDCOLUMNS=7200
GLOBALGRIDROWS=3600
GRIDTYPE=Geographic Lat/Lon
GRINGPOINTLATITUDE.1=90,90,-90,-90
GRINGPOINTLONGITUDE.1=-180,180,180,-180
GRINGPOINTSEQUENCENO.1=1,2,3,4
HDFEOSVersion=HDFEOS_V2.16
HORIZONTALTILENUMBER=00
INPUTFILESNAME=Multi-Source Data
INPUTPOINTER=Multi-Source Data
INSTITUTENAME=BEIJING
LOCALGRANULEID=GLASS02B06.V04.A2013169.2017128.hdf
LOCALVERSIONID=V04
long_name=Black-sky Albedo in Visible band
NORTHBOUNDINGCOORDINATE=90
PARAMETERNAME.1=GLASS02B06
PGEVERSION=V04
PROCESSINGENVIRONMENT=High Performance Computing System
PRODUCTDATEANDTIME=2017-05-08 16:00:12
PRODUCTIONDATETIME=2017-05-08 16:00:12
PRODUCTNAME=Surface
PRODUCTQUALITY=CLOUDREMOVED
REPROCESSINGACTUAL=reprocessed
REPROCESSINGPLANNED=further update is anticipated
scale_factor=0.0001
scale_factor_err=0
SHORTNAME=GLASS02B06
SOUTHBOUNDINGCOORDINATE=-90
TILENUMBER=H00V00
units=Albedo,no units
valid_range=0, 10000
VERSIONID=1
VERTICALTILENUMBER=00
WEBSITE=http://glass-product.bnu.edu.cn
WESTHBOUNDINGCOORDINATE=-180
_FillValue=-1
Corner Coordinates:
Upper Left (-20015109.354,10007554.677) (124d17'29.21"W, 90d 0' 0.00"N)
Lower Left (-20015109.354, 8895604.157) ( 43d25'16.73"E, 80d 0' 0.00"N)
Upper Right (-18903158.834,10007554.677) ( 77d21'53.56"W, 90d 0' 0.00"N)
Lower Right (-18903158.834, 8895604.157) (101d 0'32.47"E, 80d 0' 0.00"N)
Center (-19459134.094, 9451579.417) (152d 6' 0.67"E, 85d 0' 0.00"N)
Band 1 Block=7200x3600 Type=Int16, ColorInterp=Gray
Description = Black-sky Albedo in Visible band
NoData Value=-1
Unit Type: Albedo,no units
Offset: 0, Scale:
Dr. Michael Sumner
Software and Database Engineer
Australian Antarctic Division
203 Channel Highway
Kingston Tasmania 7050 Australia
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20181130/b158979f/attachment.html>
