[gdal-dev] HDF data mis-applied sinusoidal
Andre Joost
andre+joost at nurfuerspam.de
Fri Nov 30 07:02:56 PST 2018
Hi Michael,
running eosdump on the file, I get:
File Size: 94926773
Number of grids: 1
Number of swaths: 0
Number of points: 0
Grid: GLASS02B06
projection: SNSOID
griddataclash:
GRID GLASS02B06 {{{
xdim: 7200
ydim: 3600
upleft: -2.00151e+07, 1.00076e+07
lowright: -1.89032e+07, 8.8956e+06
PROJECTION {
projection: 16
zone: -1
sphere: -1
param: ...
6.37101e+06 0 0 0 0 0 0 0
0 0 0 0 0 3.14511e+35 4.21472e-153 1.72352e+45
pix: 0
origin: 0
So they defined the wrong projection, and gdal can't do much about it.
You can sanitize it with gdal_translate -a_ullr -180 90 180 -90 -a_srs
EPSG:4326 src dst
HTH,
Andre Joost
Am 29.11.18 um 21:31 schrieb Michael Sumner:
> Hello, these data in HDF4 format are interpreted as being in sinusoidal
> projection, I guess some conflation with the MODIS logic about some
> products (?).
> ftp://ftp.glcf.umd.edu/glcf/GLASS/ABD/MODIS/0.05D/2013/
> Particular file is here, but note there's also an auxiliarly .hdf.xml with
> it:
> ftp://ftp.glcf.umd.edu/glcf/GLASS/ABD/MODIS/0.05D/2013/GLASS02B06.V04.A2013169.2017128.hdf
> A plot of the first subdataset shows that it is trivially in regular
> longlat (or eqc), the gdalinfo output is below.
> I'd appreciate any insights into why this is interpreted this way, and
> whether the GDAL detection logic could be improved - or whether the data
> providers need to update the internal metadata.
> Cheers, Mike.
> gdalinfo --version GDAL 2.3.2, released 2018/09/21
> gdalinfo
> HDF4_EOS:EOS_GRID:"GLASS02B06.V04.A2013169.2017128.hdf":GLASS02B06:ABD_BSA_VIS
> Driver: HDF4Image/HDF4 Dataset
> Files: GLASS02B06.V04.A2013169.2017128.hdf
> Size is 7200, 3600
> Coordinate System is:
> PROJCS["unnamed",
> GEOGCS["Unknown datum based upon the custom spheroid",
> DATUM["Not specified (based on custom spheroid)",
> SPHEROID["Custom spheroid",6371007.181,0]],
> PRIMEM["Greenwich",0],
> UNIT["degree",0.0174532925199433]],
> PROJECTION["Sinusoidal"],
> PARAMETER["longitude_of_center",0],
> PARAMETER["false_easting",0],
> PARAMETER["false_northing",0],
> UNIT["Meter",1]]
> Origin = (-20015109.353999998420477,10007554.676999999210238)
> Pixel Size = (154.437572175972150,-308.875144351944300)
> Metadata:
> add_offset=0
> add_offset_err=0
> ASSOCIATEDINSTRUMENTSHORTNAME.1=AVHRR
> ASSOCIATEDPLATFORMSHORTNAME.1=NOAA
> ASSOCIATEDSENSORSHORTNAME.1=AVHRR
> BANDDEFINITION=Surface
> CHARACTERISTICBINSIZE=926.6
> DATACOLUMNS=7200
> DATAROWS=3600
> DATASETNAME=GLASS02B06
> DAYNIGHTFLAG=Both
> EASTHBOUNDINGCOORDINATE=180
> EXCLUSIONGRINGFLAG=N
> GLOBALGRIDCOLUMNS=7200
> GLOBALGRIDROWS=3600
> GRIDTYPE=Geographic Lat/Lon
> GRINGPOINTLATITUDE.1=90,90,-90,-90
> GRINGPOINTLONGITUDE.1=-180,180,180,-180
> GRINGPOINTSEQUENCENO.1=1,2,3,4
> HDFEOSVersion=HDFEOS_V2.16
> HORIZONTALTILENUMBER=00
> INPUTFILESNAME=Multi-Source Data
> INPUTPOINTER=Multi-Source Data
> INSTITUTENAME=BEIJING
> LOCALGRANULEID=GLASS02B06.V04.A2013169.2017128.hdf
> LOCALVERSIONID=V04
> long_name=Black-sky Albedo in Visible band
> NORTHBOUNDINGCOORDINATE=90
> PARAMETERNAME.1=GLASS02B06
> PGEVERSION=V04
> PROCESSINGENVIRONMENT=High Performance Computing System
> PRODUCTDATEANDTIME=2017-05-08 16:00:12
> PRODUCTIONDATETIME=2017-05-08 16:00:12
> PRODUCTNAME=Surface
> PRODUCTQUALITY=CLOUDREMOVED
> REPROCESSINGACTUAL=reprocessed
> REPROCESSINGPLANNED=further update is anticipated
> scale_factor=0.0001
> scale_factor_err=0
> SHORTNAME=GLASS02B06
> SOUTHBOUNDINGCOORDINATE=-90
> TILENUMBER=H00V00
> units=Albedo,no units
> valid_range=0, 10000
> VERSIONID=1
> VERTICALTILENUMBER=00
> WEBSITE=http://glass-product.bnu.edu.cn
> WESTHBOUNDINGCOORDINATE=-180
> _FillValue=-1
> Corner Coordinates:
> Upper Left (-20015109.354,10007554.677) (124d17'29.21"W, 90d 0' 0.00"N)
> Lower Left (-20015109.354, 8895604.157) ( 43d25'16.73"E, 80d 0' 0.00"N)
> Upper Right (-18903158.834,10007554.677) ( 77d21'53.56"W, 90d 0' 0.00"N)
> Lower Right (-18903158.834, 8895604.157) (101d 0'32.47"E, 80d 0' 0.00"N)
> Center (-19459134.094, 9451579.417) (152d 6' 0.67"E, 85d 0' 0.00"N)
> Band 1 Block=7200x3600 Type=Int16, ColorInterp=Gray
> Description = Black-sky Albedo in Visible band
> NoData Value=-1
> Unit Type: Albedo,no units
> Offset: 0, Scale:
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
