[gdal-dev] HDF data mis-applied sinusoidal
Michael Sumner
mdsumner at gmail.com
Fri Nov 30 13:42:09 PST 2018
Thanks for clarifying!
Cheers, Mike
On Sat, Dec 1, 2018, 02:04 Andre Joost <andre+joost at nurfuerspam.de> wrote:
> Hi Michael,
> running eosdump on the file, I get:
> File Size: 94926773
> Number of grids: 1
> Number of swaths: 0
> Number of points: 0
> Grid: GLASS02B06
> projection: SNSOID
> griddataclash:
> GRID GLASS02B06 {{{
> xdim: 7200
> ydim: 3600
> upleft: -2.00151e+07, 1.00076e+07
> lowright: -1.89032e+07, 8.8956e+06
> PROJECTION {
> projection: 16
> zone: -1
> sphere: -1
> param: ...
> 6.37101e+06 0 0 0 0 0 0 0
> 0 0 0 0 0 3.14511e+35 4.21472e-153 1.72352e+45
> pix: 0
> origin: 0
> So they defined the wrong projection, and gdal can't do much about it.
> You can sanitize it with gdal_translate -a_ullr -180 90 180 -90 -a_srs
> EPSG:4326 src dst
> HTH,
> Andre Joost
> Am 29.11.18 um 21:31 schrieb Michael Sumner:
> > Hello, these data in HDF4 format are interpreted as being in sinusoidal
> > projection, I guess some conflation with the MODIS logic about some
> > products (?).
> > ftp://ftp.glcf.umd.edu/glcf/GLASS/ABD/MODIS/0.05D/2013/
> > Particular file is here, but note there's also an auxiliarly .hdf.xml
> with
> > it:
> ftp://ftp.glcf.umd.edu/glcf/GLASS/ABD/MODIS/0.05D/2013/GLASS02B06.V04.A2013169.2017128.hdf
> > A plot of the first subdataset shows that it is trivially in regular
> > longlat (or eqc), the gdalinfo output is below.
> > I'd appreciate any insights into why this is interpreted this way, and
> > whether the GDAL detection logic could be improved - or whether the data
> > providers need to update the internal metadata.
> > Cheers, Mike.
> > gdalinfo --version GDAL 2.3.2, released 2018/09/21
> > gdalinfo
> HDF4_EOS:EOS_GRID:"GLASS02B06.V04.A2013169.2017128.hdf":GLASS02B06:ABD_BSA_VIS
> > Driver: HDF4Image/HDF4 Dataset
> > Files: GLASS02B06.V04.A2013169.2017128.hdf
> > Size is 7200, 3600
> > Coordinate System is:
> > PROJCS["unnamed",
> > GEOGCS["Unknown datum based upon the custom spheroid",
> > DATUM["Not specified (based on custom spheroid)",
> > SPHEROID["Custom spheroid",6371007.181,0]],
> > PRIMEM["Greenwich",0],
> > UNIT["degree",0.0174532925199433]],
> > PROJECTION["Sinusoidal"],
> > PARAMETER["longitude_of_center",0],
> > PARAMETER["false_easting",0],
> > PARAMETER["false_northing",0],
> > UNIT["Meter",1]]
> > Origin = (-20015109.353999998420477,10007554.676999999210238)
> > Pixel Size = (154.437572175972150,-308.875144351944300)
> > Metadata:
> > add_offset=0
> > add_offset_err=0
> > ASSOCIATEDINSTRUMENTSHORTNAME.1=AVHRR
> > ASSOCIATEDPLATFORMSHORTNAME.1=NOAA
> > ASSOCIATEDSENSORSHORTNAME.1=AVHRR
> > BANDDEFINITION=Surface
> > CHARACTERISTICBINSIZE=926.6
> > DATACOLUMNS=7200
> > DATAROWS=3600
> > DATASETNAME=GLASS02B06
> > DAYNIGHTFLAG=Both
> > EASTHBOUNDINGCOORDINATE=180
> > EXCLUSIONGRINGFLAG=N
> > GLOBALGRIDCOLUMNS=7200
> > GLOBALGRIDROWS=3600
> > GRIDTYPE=Geographic Lat/Lon
> > GRINGPOINTLATITUDE.1=90,90,-90,-90
> > GRINGPOINTLONGITUDE.1=-180,180,180,-180
> > GRINGPOINTSEQUENCENO.1=1,2,3,4
> > HDFEOSVersion=HDFEOS_V2.16
> > HORIZONTALTILENUMBER=00
> > INPUTFILESNAME=Multi-Source Data
> > INPUTPOINTER=Multi-Source Data
> > INSTITUTENAME=BEIJING
> > LOCALGRANULEID=GLASS02B06.V04.A2013169.2017128.hdf
> > LOCALVERSIONID=V04
> > long_name=Black-sky Albedo in Visible band
> > NORTHBOUNDINGCOORDINATE=90
> > PARAMETERNAME.1=GLASS02B06
> > PGEVERSION=V04
> > PROCESSINGENVIRONMENT=High Performance Computing System
> > PRODUCTDATEANDTIME=2017-05-08 16:00:12
> > PRODUCTIONDATETIME=2017-05-08 16:00:12
> > PRODUCTNAME=Surface
> > PRODUCTQUALITY=CLOUDREMOVED
> > REPROCESSINGACTUAL=reprocessed
> > REPROCESSINGPLANNED=further update is anticipated
> > scale_factor=0.0001
> > scale_factor_err=0
> > SHORTNAME=GLASS02B06
> > SOUTHBOUNDINGCOORDINATE=-90
> > TILENUMBER=H00V00
> > units=Albedo,no units
> > valid_range=0, 10000
> > VERSIONID=1
> > VERTICALTILENUMBER=00
> > WEBSITE=http://glass-product.bnu.edu.cn
> > WESTHBOUNDINGCOORDINATE=-180
> > _FillValue=-1
> > Corner Coordinates:
> > Upper Left (-20015109.354,10007554.677) (124d17'29.21"W, 90d 0' 0.00"N)
> > Lower Left (-20015109.354, 8895604.157) ( 43d25'16.73"E, 80d 0' 0.00"N)
> > Upper Right (-18903158.834,10007554.677) ( 77d21'53.56"W, 90d 0' 0.00"N)
> > Lower Right (-18903158.834, 8895604.157) (101d 0'32.47"E, 80d 0' 0.00"N)
> > Center (-19459134.094, 9451579.417) (152d 6' 0.67"E, 85d 0' 0.00"N)
> > Band 1 Block=7200x3600 Type=Int16, ColorInterp=Gray
> > Description = Black-sky Albedo in Visible band
> > NoData Value=-1
> > Unit Type: Albedo,no units
> > Offset: 0, Scale:
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/gdal-dev
Dr. Michael Sumner
Software and Database Engineer
Australian Antarctic Division
203 Channel Highway
Kingston Tasmania 7050 Australia
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20181201/025fdae0/attachment.html>
