[gdal-dev] Translate leaves additional PAM .aux.xml file
Even Rouault
even.rouault at spatialys.com
Fri Oct 5 04:38:01 PDT 2018
On vendredi 5 octobre 2018 11:58:14 CEST Robert Coup wrote:
> Hi all,
> I have some datasets I've been converting via gdal.Translate() to
> self-contained Cloud-style GeoTIFFs (ie. as one file). For a handful of
> datasets that have band descriptions:
Can you give a procedure to reproduce this ? I couldn't from a quick test.
Things tend to go to PAM a bit too easily.
Sometimes this is a matter of using poBand->GDALRasterBand::SetDescription()
to short-circuit PAM instead of poBand->SetDescription()
Even
http://www.spatialys.com
